RE: New Decathlons From Seagull 91 and 120 Size!
Here is the link to the manual on Horizons site
[link]http://www.horizonhobby.com/ProdInfo/Files/SEA2125-Manual.pdf[/link]
Page 20 shows drilling a 5 mm diameter hole down thru the wing and using either a 3x50mm or an M4x60mm bolt down thru the wing the directions show different size bolts in the graphics the acutal size bolt that came with my kit is the 60mm
Ground handling was very good (I have flown cubs a bit so I am used to short wheel base planes with large wing spans) Take offs were uneventful I rolled on the power evenly and let it build speed before pulling back on the elevator. It tracked straight and showed no tendency to torque roll on take off
