RCU Forums - View Single Post - OS 91 FX problem
Old 01-07-2011 | 08:32 PM
delman
Default RE: OS 91 FX problem
As someone suggested, if your needle housing is the original combined backplate with the needle housing built in, a remote needle assembly should fix the problem. Mine has that type backplate. I like the front needle carb so I installed a Magnum / ASP 91 carb on the engine to fix mine.
