RE: Mojo 40 Build Thread
The problem with building two left is that the taper you need to sand would be going opposite ways. I think the taper should be the same side on LHS and RHS. It would either look funny or cause flight issues by having the taper on top on one side and bottom on the other because after tapering, they are not symetric (flat on the bottom and taper on top).
In temrs of servos, these have more torque than 3010. I hooked them up today and there was no jitter...time will tell. Like I said, it is a test.
