RE: RC Lander Lighting System
Well I have a set of these lights and I have just spent 2 hours trying to set them up and they are terrible. The wireing diagram/instructions are terrible. Once you see which side of the controller pin board is the signal side you then see that some of the LED's are wired with just a red and black wire and others with a red and white wire. When I wire mine up as above and after looking at the useless instructions the main lights just stay on and dont work at all on the Retract channel which is the one I have set them up on to switch on and off.
As for the afterburner ring well again I have set it up as above and it will not work at all.
This is in my view a terrible product and will give you hours of frustration before you throw it in the bin.
Tim your products are generally good but you have completly let yourself down with his one I am afraid
Dennis
