RCU Forums - View Single Post - Mick Reeves Hunter
Old 01-08-2011 | 12:51 PM
dabevan's Avatar
dabevan
Default RE: Mick Reeves Hunter
Wing construction is fairly standard, except the spar is a kind of ladder structure. The main advantage of this is that all the ribs can be slotted in dry.
The disadvantage (for a builder like me) is that while a traditional spruce top an bottom spar holds the wind firm in two directions this ladder spar can allow the tip to move backwards and forwards while gluing and I let mine move backwards by ¼” leaving my spar a bit bent. - I spotted this and was able to pin it straight while sheeting the front portion of the wing so no permanent damage done!
ID:	1544142   Click image for larger version
ID:	1544143   Click image for larger version
