ORIGINAL: beto9
The ''manual'' (2 pages, chinglese) can be downloaded from HobbyKing, go to the receiver page and under files... there it is!
In any case
FrSky 2.4GHz Radio Control System
Instruction Manual for TF Receivers
1. TF Receivers
Read the instruction manual and set up the devices as described below.
1.1 Compatibility:
Futaba: TM7, TM8, TM10, TM14, etc.
FrSky: TF-8M, TF-14M
1.2 Specifications:
Model: TFR8
Number of channel: 8
Operating Voltage Range: 4V~10V
Dimension: 53mm*30mm*11mm
Weight: 13.5g
2. Setup
2.1 Bind procedure:
Turn on the transmitter, connect the battery to the receiver while pressing receiver’s F/S button. After the RED LED is off and GREEN LED is solid, the binding process is completed and working mode is activated.
2.2 Setting failsafe:
TF series receivers support failsafe function for all channels.
After the receiver has been bind, press briefly the F/S button of the receiver, the GREEN LED of the receiver will flash twice, the failsafe is set up successfully.
If you do not need the failsafe function any more, just re-bind the receiver to default failsafe mode.
2.3 LED status:
RED LED GREEN LED Mode
Off On Working mode
On On Waiting to be bind
Flash On Signal lost
On Flash twice Set failsafe
Should you have any questions or need further queries, pls send e-mails to us.
Technical support:
[email protected] or
[email protected].
Just a couple of clarifications to the TFR8 instructions.
1. The Fail Safe settings in the transmitter for each channel MUST be disabled. Otherwise the servos will twitch about once per second.
2. The brand new TFR8 receivers are preset to High Speed mode. This is only suitable for use with digital servos. Trying to operate an analog servo in high speed mode usually destroys the servo within a few seconds. Therefore the receiver must be set to normal speed for use with analog servos.
Here's how to set the receiver for high or low speed:
a. Leave transmitter turned off.
b. Power up the receiver.
c. Press and hold the button for 6 seconds, then release.
d. The red LED will blink faster in High Speed, and blink slower in Normal mode.
