RCU Forums - View Single Post - Mick Reeves Hunter
Old 01-08-2011 | 01:55 PM
dabevan's Avatar
dabevan
Default RE: Mick Reeves Hunter
For the wings I used the supplied moulded tips, these are glued to a balsa rib and then glued to the tips - But, my tip is 1/8” thicker than Mick intended (as Ive got 1/16" balsa sheet top and bottom) so I had to make up a pair of thicker ribs to compensate. The plastic tips had enough flex to fit the thicker profile.
ID:	1544184   Click image for larger version
ID:	1544185   Click image for larger version
