RCU Forums - View Single Post - Redcat Ground Pounder Problems
Old 01-08-2011 | 04:21 PM
fullbore55
Default RE: Redcat Ground Pounder Problems
It is just the steering that is a problem. I switched the steering to channel 2 in the receiver and it still is very slow to turn when it turns at all. I only get about 5 degrees(almost nothing) of turning radius. I thought maybe the trims were set at the max but they are at zero. The rear steering is not working at all. When i lift the truck off the ground the rear will almost budge 1-2mm. The front will turn the same, but will go fullrange if i guide it through with my help. It seems it's not getting power. It only worked full range on the first test run for about five minutes, first day. I thought my little guy didn't know how to steer but it's not him.
