RCU Forums - View Single Post - Black Magic VF3 E build thread!
Old 01-09-2011 | 01:09 AM
  #149
Jason Arnold's Avatar
Jason Arnold
Default RE: Black Magic VF3 E build thread!
A little more progress...
Turtle deck is now complete and glued to the fuse. Polyurethane was the glue of choice... Just a smear of it is all that's needed.
I found that the turtle deck template drawings supplied in the kit are a little too small in height. I had to add some balsa (2mm) to the top of the fuse to lift the turtle deck up to match with the canopy. This balsa was glued to the top of the fuse and a small piece of 1/16th balsa was added to hold the foam core in correct position. The core naturally pulls in so the balsa prevents this. You may be able to see what I'm on about from the pictures. Masking tape was used to hold everything in position while the glue cured.
Next will be fitting the cowl.... Starting to look like a plane now...
Cheers,
Jason.
ID:	1544549   Click image for larger version
ID:	1544550   Click image for larger version
ID:	1544551   Click image for larger version
ID:	1544552   Click image for larger version
