RE: OS 91 FX problem
While you are waiting on the new valve assembly, try the teflon tape. Doesn't cost you anything, if you have some in the garage. If not, shouldn't be more then a $1 at the hardware. Also, if you are using a tuned pipe, use an OS -A-5 plug. It is a colder running plug for the higher RPM's and temperature.
