ORIGINAL: TimBle
Zor, Futaba specifically states in the Rx instruction manual that the FASST receiver must not be mounted in foam but rather on 4 velcro feet. the new 2.4GHz kit is not vibration sensitive but are more heat sensitive. The style fitting techniques used for FM does not apply here.
TimBle
Your post above gives the readers the impression that I recommended to wrap the receiver in foam.
I did not do that.
In post #33 I wrote
quote word for word ___
Any electronic should be isolated from vibrations and held within their specified tempeature range as specified by the manufacturer.
unquote
which leaves the builder / assembler to use his initiative to decide on his/her mounting method.
Zor
