ORIGINAL: TimBle
Zor, Futaba specifically states in the Rx instruction manual that the FASST receiver must not be mounted in foam but rather on 4 velcro feet. the new 2.4GHz kit is not vibration sensitive but are more heat sensitive. The style fitting techniques used for FM does not apply here.
The above text (now in red) seemed to indicate that I had said to mount the receiver in foam.and you wanted to point out to me that it should.not.
The following format could not have been interpreted that Zor had said that.
Hi Zor,
Reminding everyone thatFutaba specifically states in the Rx instruction manual that the FASST receiver must not be mounted in foam
No big deal now that things have been rectified.
Zor
