ORIGINAL: Twinhydro
While all you guys are here ...a question . In getting ready for my radio installation , on the UFO I noticed that the Elevator has two pushrods . Is the normal plan for two servos with ''Y'' harness ? Never dealt with this before . thanks for any guidance in this area .
Twinhydro
That’s Sullivan hardware in the plane (Solid steel Rod Type) part#S511 or S519.
I assume the builder was planning to connect the two elevator pushrods in the fuse into a single rod to the servo.
I’ve done this similar installation with the Sullivan solid hardware.
Hopefully the builder secured the red outer tubes within the fuse.
Good Luck with the installation.
