RE: Equalizer II
Hi,
You do not need to go into the option menu unless you want to set end-point hold. When you start to actually
adjust the servos, start with function on zero (0). You want to use your mechanical linkage to get the travels
as close to what you want on high-rates as possible. Then use the Equalizer to tweak the positions. The
"optimal" position is the most travel you want the servo to use. For the most part, just set the servos in the
wing.
