RCU Forums - View Single Post - PRIMING PROBLEM
Old 01-10-2011 | 07:45 AM
DMENACE
Default PRIMING PROBLEM
Need advice,
I have a TOC53MM w/reed valve assembly, the engine performs beautifully after the first start .The problem begins when I try to start the engine for the first time of the day, even closing the carb with my thumb to prime it there is no suction of fuel to the carburator so what a do is to put some fuel direct to the carb to start it the first time. No leaks, no clinches visible in fuel lines and choke butterfly closes thight.
Any advice or ideas are welcome.
Best Regards
DMENACE
