I'm in need of you guys help here. I'm currently working on a TF P-47 1/5 scale and have come accross a little delima at least for me. In the kit plans it shows quite a bit of right hand thrust on the engine. And with that it realy looks wrong and even worst with the cowel on it. Should I eleminate the thrust on the engine or maybe redrill the engine mount holes in the fire wall and set the engine off center then adjust the cowel to make it look square. I would realy prefer to set the engine up with 0 thrust and go from there.
