RCU Forums - View Single Post - G2 will not allow change to control surface
Old 08-06-2003 | 02:09 AM
elevator_up
Default G2 will not allow change to control surface
Krister,
Thanks for the tip, and I think I closer but not there yet. I was able to set up the 2 servos one for each side and I was able to get flaps working properly, but not able to get flaperons. I got stuck on the screen where it requires control surface dimensions, as it will not allow you to overlap the flaps with the ailerons. How did you overcome this ?
My workaround was to shorten the ailerons length so that I could have small 5 inch flaps. These work well, but I think that by shortening the aileron I changed the flying characteristics just a little.
