RCU Forums - View Single Post - G2 will not allow change to control surface
Old 08-06-2003 | 04:02 AM
SAS902's Avatar
SAS902
Default G2 will not allow change to control surface
For flaps, as far as I know you do have to shorten the ailerons unless there is room for the flaps already. I do not think ailerons and flaps can overlap.
So what you are doing sounds correct to me. You are right, it might change the flying characteristics a bit. If you want more aileron authority after shortening them, maybe you can enlarge the aileron control throw somewhat?
Just to avoid any confusion - the above is only applicable to flaps. For flaperons , you should not have to change any control surface dimensions at all.
Krister
