RCU Forums - View Single Post - won't aileron roll?
Old 01-11-2011 | 08:20 AM
Rodney
Default RE: won't aileron roll?
One thing that will help the roll rate if you can do it is to remove most or all of the dihedral. This is usually not practical to do as you have to cut the wing in half and rejoin the halves with little or no dihedral. Re attaching the wing halves can be a problem as the joint has to be reinforced with a new joiner or fiberglass patch.
