Code:
**** Digital ignition for 2 stroke engines. SPORTDEVICES 4/3/2005
**** NOTE: use compiler: PCW v2.619
**** Digital parts: PIC16F84a, XTAL 4MHz
**** Complete schematic: www.sportdevices.com/ignition/ignition.htm
**** To ask any question: [email protected]
#include <16F84a.H>
#fuses XT,NOWDT,PUT
#use fast_io(a)
#use delay(clock=4000000)
//setup values
#define prescaler 7 //2^7=128
#define delay_multiple 8 //8 us, min 3 us
#define low_rpm_pulse true //does it generate pulses at low rpm?
#define low_rpm_multiple 40 //us, to calculate degrees at low rpm (8 * 2.5 = 40)
#define scr_pulse 200 //scr spark time, microseconds
#define pulse_polarity 0 //0-activates low
#define min_rpm 200 //min rpm value, if lower the program starts again
#define min_period 31
#define max_period 60000000/(2^prescaler)/min_rpm
int const ignition0[64]=
{48,49,51,52,54,56,57,59,60,62,64,65,67,68,70,72,73,75,76,78,80,81,83,84,
86,88,89,91,92,94,96,97,99,100,102,104,105,142,145,147,149,151,153,155,157,
160,162,164,166,168,170,172,174,177,179,181,183,185,187,189,192,194,196,198};
int const ignition1[64]=
{22,23,25,27,29,31,33,35,37,39,41,44,46,49,51,54,56,59,62,65,68,70,73,77,80,83,86,89,
93,96,100,103,106,108,110,112,115,117,119,122,124,127,129,131,134,136,139,141,144,146,
149,151,154,157,159,162,165,167,170,173,175,178,181,184};*/
//Note: Delay values are calculated in multiples of 4 microseconds
//first value is for 15121 RPM (TMR0 count=31) and last value is for 4987 RPM (TMR0 count=94)
#define pickup PIN_B0 //pin 6
#define thyristor PIN_A2 //pin 1
#define LED PIN_A4 //pin 1
#define curve_sel PIN_B2 //pin 8
#define inhibit PIN_B1 //pin 8
#byte TMR0=0x01
#byte PORTA=0x05
#byte PORTB=0x06
#byte INTCON=0x0b
#byte OPTION_REG=0x81
int tmr0h,perl,perh;
int16 per;
#define copy16(a,b) #asm \
movf a,w \
movwf b \
movf &a+1,w \
movwf &b+1 \
#endasm
#int_global
void int_tmr0()
tmr0h++;
bit_clear(INTCON,2);
#inline
void wait_pulse()
#if pulse_polarity==0
while (!input(pickup)); //wait line goes high
while (input(pickup)); //wait line goes low
#else
#endif
perl=TMR0; perh=tmr0h;
TMR0=0; tmr0h=0;
#inline activate_SCR()
output_high(inhibit); //switch OFF DC/DC converter (if present)
output_high(LED); // led off
output_high(thyristor);
delay_us(scr_pulse);
output_low(thyristor);
delay_us(500); //this value is TBD (to be defined)
output_low(inhibit); //switch ON DC/DC converter (if present)
void main(){
int retardo;
boolean first=true;
INTCON=0xa0; //T0IE=1
OPTION_REG=prescaler-1; //PULLUP on, 2^prescaler=128
set_tris_a(0x01);
set_tris_b(0x05); //pin b2 input (curve selector), PIN B0 input (pickup)
output_low(LED);
delay_ms(50);
output_high(LED);
delay_ms(100);
while (true)
//first pulse is not processed because the period can not be calculated until the second pulse
if(first) { wait_pulse(); first=false; }
wait_pulse();
copy16(perl,per);
if ((per>=min_period)&&(per {
perl=perl-min_period;
#ifdef ignition1
if(input(curve_sel))
retardo=ignition1[perl];
else
#endif
retardo=ignition0[perl];
retardo=retardo-8; //delay adjust (substract 8*4=32 us)
//do delay
#asm
bucle: #endasm
delay_cycles(delay_multiple-3);
#asm
decfsz &retardo,f
goto bucle
#endasm
activate_SCR();
else
if (per>=max_period) first=true; //if rpm is too slow, engine is stoped
#if (low_rpm_pulse)
else
if (per>=min_period+sizeof(ignition0))
//do delay
perl++;
perh++;
#asm
loop2: #endasm
delay_cycles(low_rpm_multiple-3);
#asm
decfsz perl,f
goto loop2
decfsz perh,f
goto loop2
#endasm
activate_SCR();
#endif
} //while
} //main
