RE: Strange RCEXL problem...
I don't know if I have ever gotten a definitive answer to this question:
The RCEXL ignition is a fully shielded type, so does it or does it not require a resistor plug?
I am running resistor plugs right now. If it doesn't need them, non-resistor plugs should give it a hotter spark. Right?
Think this unit will keep running Terry? (I won't hold whatever you say against you if it doesn't work out, but your judgement would be far better than mine on this issue.)
AV8TOR
