RCU Forums - View Single Post - How much space should be between...
Old 01-11-2011 | 06:43 PM
swampyankee
Default How much space should be between...
the rudder and fin? The print shows 1/8th of an inch. I'm doing scale hinging with tube, wire and gudgeon. So should I go with the amount of space shown on plans or is this not the correct spacing and I should know something else about this? It's a Meister Zero so you know what I don't know what I'm talking about.
Here's a couple of pics.
And maybe you can tell me if I can use the same number of the hinges the real plane used, 2 instead of three as is called for on the plan.
Thanks, Jim.
