spandexman What are you using to put the clips on?? I find a good needle nose pliers usually works for such things.
Nice set of part you got there Stryker.
My rustler does not have a sliper cluch on it, just a straight spur gear.
Should it be upgraded when i finaly go brushless??
I just got some shocks off my friend that he had gotten for his slash. They where not quite the right fit and so he go another set. Only issues is that they have a larger eye hole on the top part than the standard screw that goes there for the rustler, so put some tape around the screw for now to fill the space. They are all the same length all around so where to short at first for the back but just moved the placement in some. Also had to put in my old spring for the back set, the springs that came with did not hold up to the weight of the rear end.
Will have to post some new pics later.
