RE: Weatronic 2.4 RF diagnostic tool
Can anyone tell me about the external gyro input sockets? I have come up with a cunning plan to allow us to use a very useful device, not a gyro, with the Wea 12-22 by feeding its output back into the Wea via the external gyro socket, but only if the external gyro sockets work as I expect they might, and they are not described in the old Mhz manual or the new 2.4Ghz manual or Gerhard's instructions about using the internal gyros. So before I connect up the device to the external gyro socket I want to be sure I am not about to make it smoke!
Do they work like this - lets say aileron control is assigned to servo output 1. The external gyro is connected to servo output 1, and the gyro's output which would normally go to a servo is instead plugged into external gyro socket 1 on the rx. We want servos 2 and 3 to get the gyro output so in the servo allocation screen we assign ext gyro 1 to the servos, and those servo then get the signal from the gyro, not from the tx, in other words the gyro output is fed straight through from the external gyro socket to servos 2 and 3 without modification, other than the usual adjustable servo curve in the servo set-up screen
Harry
