RCU Forums - View Single Post - Work Bench & Model Room
Old 01-12-2011 | 05:21 AM
JRM23
Default RE: Work Bench & Model Room
Scooterinvegas,
I think you are right, that the table top should be at least 30 inches.The building board that I am using now is 24" and I always have several rows of CA or small tools set at the edge of the building board, so the extra room is need. I have also thought about making a "L" shaped table. I could build on one side, sand on the other side or install the covering. I often find myself building on several different section of a plane at the same time and this would be good for that.
Foodstick,
Your idea for the tool chest is a great idea and I just happen to have a tool chest that I could use for this. Now I am thinking about going and buying a second tool chest and I could make make a table top to go across both of them. I will need the room as I do have several GIANT scale airplanes to build. The storage room in these box's are perfect of keeping all of the things that we need and use each day.
Again, thank you to everyone that have giving me such great ideas and advise.
John<br type="_moz" />
