RE: COMP-ARF A-4 BUILD
C-Arf A4 instructions, Where? Please post some photos of your nose wheel instal when you have time... As I understand your post you have no clearance issues when mounting gear on lower rail. Mine will hit nose wheel on fuse when retracting and when extended the air cylinder binds on aft lower section of fuse. Can their be this much variance between models?
Phil<br type="_moz" />
