RCU Forums - View Single Post - U Can Do 3D .46 Main Wing Question
Old 08-05-2003 | 06:55 PM
Heads_Up
Default U Can Do 3D .46 Main Wing Question
Originally posted by poptartcrust
nope, we had a problem with the tail (elevator) sections c snapping off, but that was from guys with 4 channel radios who made a huge bend in one of the 2-56 pushrods.(they also flew 90 miles per hour) i would strongly reccomend that you DO NOT use standard servosand the supplied cot\ntrol horn-pushrod assemblies. i have 4 40 rods and sullivan metal horn things on mine.
P.S. It flies awesome with a YS .63!!!
thanx for the advice
i will be running an os 50 sx with mini tune pipe spinning a 12.25 x 3.75 apc prop. plan on going with 100 oz. torque metal gear servos on everything but the throttle. i hardly ever use the supplied push-rods. will go 4-40 with ball links and all metal arms and horns. i had a kangke fun 50 and it was a blast ... so much fun, i forgot that the os 50 sx will eventually run out of fuel (it did right in the middle of a prop hang at about 20 feet) ... d'oh!
easier to replace it with the ucd than it is to fix it ... it is now in the closet with my other winter project planes
rick
