RCU Forums - View Single Post - Hal DeBolt Interceptor MK 1
Old 01-12-2011 | 01:46 PM
doxilia's Avatar
doxilia
Default RE: Hal DeBolt Interceptor MK 1
ORIGINAL: Roguedog
Bill,
After seeing a pic of the Interceptor Jr. in flight I had to have the plans for this. Used the article and made a set of plans with as accurate dimensions as possible.
I didn't like the way the plans where arranged so I modified, combined, separated, and hopefully made them easier to use.
Bryan,
is this one of the results of direct scanning of the magazine? If so, they turned out just peachy!
For slightly more universality, I converted them to PDF which resulted in them also shedding about 50% of their data size (therefore, somewhat faster download). I know you're a die hard TIF guy, I guess I'm the die hard vector guy so here they are posted for others convenience if some prefer PDF. In order posted:
[ul][*] Fuse, Wing & Stab[*] Fuse & Formers[*] Fuse Top[*] Wing[*] Stab
[/ul]
Nice model!
David.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
