RCU Forums - View Single Post - THRUST VS. PLANE WEIGHT?
Old 01-12-2011 | 01:52 PM
pe reivers
Default RE: THRUST VS. PLANE WEIGHT?
You will need a DLE30, or a MVVS26 for that weight, and it will be marginal for 3D, especialy if you insist on American style in cowl mufflers.
Just to putter around, the DLE20 will be fine.
ORIGINAL: psgugrad
I guess my question is this: I'm building a 4*120 which should weigh around 12.22-12.75 pounds when done. If a DLE 20 has 14lbs of thrust with a 17-6 prop, then will the plane have plenty of power? I've had some say the DLE 20 would have more than enough power, some say it would be light on power, some say a DLE 30 would be better, some say the plane would be ridiculously overpowered with a DLE 30. The answers I've gotten are all over the board...
