RCU Forums - View Single Post - About to get a Backdraft 8E (got it!!!)
Old 01-13-2011 | 04:56 AM
nitrosportsandrunner's Avatar
Default RE: About to get a Backdraft 8E (got it!!!)
im pretty sure if it needs to be shimmed you can use a washer.
if the pinion gear can be moved closer to the ring gear, just put a washer behind the pinion gear(on shaft) to move it forward in the diff housing a tad.
