RCU Forums - View Single Post - MDS stalling
Thread: MDS stalling
Old 12-13-2002 | 09:39 PM
Mikes machines's Avatar
Mikes machines
Default MDS stalling
I have foam around the fuel tank, I glued foam strips on the formers so I could slide the tank out later if needed.
I have tilted the nose up thinking maybe it was a clunk problem, keeps idling. I have sqeezed the hose at idle listening for increase in speed. I adjusted accordingly. At idle I smack the throttle stick full open. It does not bog.
I set the top end needle for max speed then go a few clicks rich. I readjust both needles after making a change and test it nose up and full throttle from idle. It runs good on the ground. I nail it to take off. It will do a vertical climb for about 250 feet then will slowly stop acclerating. I level off then make a lap around my field. Then when I cut back to about half throttle it runs good doesnt burble or miss. I make about a half a lap and it shuts off just like you turned the key off in your car. I am pretty mechanical and I will figure it out if it kills me but right now I'm ready to take a hammer to it. (just kidding). I am seeking advice and appreciate anybodys input.
Thanks, Mike
