RE: Fuel Tank placement question..
I don't see how a header tank or a bladder tank such as the Tetra will push fuel to the engine. It may work without this, but it's getting close. Muffler pressure is good for 8 inch's of fuel head and the tank is 6" below and 2 to 3 inchs deep. You may run out. Also with little additional head it is going to have a larger reliance on suction, this means it will lean out more. Because it is well below the engine a uniflow setup will not help, nor will a header tank, nor a bladder. The only option for consistant running is a pump, or crankcase pressure with a regulator. </p>
