I have been working on him for quite a while but that one you saw in the background was cut from styrene foam, before we discovered wax and so the surface was a bit rough. But the facial features had been basically done and just needed a bit of adjustment here and there. The wax cut has come out so much better and with much finer detail. I also hadn't done anything back then on the uniform.
When are we going to see some pics of Doug in his office? Now the pressure's back on you
cheers
Patti
