RCU Forums - View Single Post - VectorFlight Sukhoi ARF tips wanted
Old 08-30-2003 | 03:39 PM
Frag
Default Belly pan
Just want to get a quick survey of opinions on how to attach the belly pan to the underside of the Sukhoi. I suppose you could epoxy it to the wing and cut hole to access the wing bolts. Or, you could use 4 or 6 servo screws to attach it to hard points of the fuse and/or wing. I'm leaning towards using screws although you'd have to remove these each time you wanted to get to take off the wing for transport. Any other ideas for a clean install?
Pete
