RE: New to RC flying
My Jetiger is very similar to yours with just 2 servos. Setting up my transmitter using the computer to program it is my problem. You said both elevons work together which I sort of understand. What I get now is if one moves up the other moves down. Mu question is how to set it to climb or put the nose downward ?
Thee computer give chouces of say channel 1 leading or following channel 2 and I have percentages I can assign. I can assign stick setting also and with all the choices I'm scratching my head. First I just need to understand what happens if you have a mix switch. How does it give you commands to take the plane up or down and at what stick position do you go up and down with your stryker?
Picture of the Jetiger attached.
Ted
