RCU Forums - View Single Post - need inserts for tires and wheels
Old 01-14-2011 | 05:29 PM
basketballfan60123
Default RE: need inserts for tires and wheels
ORIGINAL: cerealkilla024
No no no you see, I was originally being a smart*** and just f**kin with you but THEN you decided to send me PM's like the ones i recieved. You expect me not to be vicious?? Learn to take a joke, have fun. I usually do help most people on here but occasionally the noobs that jump in with questions like ''Why did I buy tires without foams'' are on the level of ''What does LiPo stand for?''. Go back to the page. It says what you are buying at the bottom, no foams mentioned. Go look thru other pre-mounts, if there is foams included it tells you what kind. *gasp* It took a whole two seconds and could have saved you these days of BS. Good day, sir.
Why don't you try joking around around at your tech school; see where that will get you.
So I guess I should just bow down to you because you are a robotics engineering student?
