RCU Forums - View Single Post - Senior header tank
Old 01-15-2011 | 05:36 AM
scale only 4 me's Avatar
scale only 4 me
My Feedback: (158)
Default RE: Senior header tank
ORIGINAL: rafeeki
Not so sure I understand your set up right.
I also use 3 lines.
#1. with clunker is the pickup line goes to engine fuel intake.
#2. Filler line which is connected to the muffler to pressurize the tank. I disconect it from mufler for refuling.
#3. The third line is strictly an overflow tube that blows out extra fuel when the tank is filled up, I plug it with a screw after refuling. This prevents me from flooding the engine when fueling.
Worth noting that #2&3 are tubes which are bent up towards the top of the tank.
You can drain the tank by using the fuel line attached to the engine but that may be cumbersom.
If u turn the model upside down u could use any of #2 or #3 to drain the fuel with.
Worth noting all of the fuel lines attached to the engine or tank should be secured to their tubes with clips.
Hope I didnt confuse u.
Rafeek
I guess there is more than on way to skin a cat, but myself and most guys I fly with put the 3rd (drain/fill) line at the bottom the the tank so the tank can be drained normally
