RCU Forums - View Single Post - G&L Hobbies 1/5 Super Chipmunk Build (short kit)
Old 01-15-2011 | 08:29 AM
TonyBuilder's Avatar
TonyBuilder
Default RE: G&L Hobbies 1/5 Super Chipmunk Build (short kit)
<div style="margin: 0in 0in 10pt">Progress.</div><div style="margin: 0in 0in 10pt">Wing.</div><div style="margin: 0in 0in 10pt">I prepped the wing as I did on the stabilizer, covered all the areas that I do not want glued. The only thing I did deferent is to apply a very tittle bit of Vaseline on the facing where the ailerons meet the wing. This hopefully will make it easier to pull apart after I cut the skin.</div><div style="margin: 0in 0in 10pt">After gluing all the skins together and sanding the outer surface I was ready to tackle this monumental stage in this build. I figured it would take two hours per skin so I started at 3:00 with the first top skin. I placed wax paper between the husk and the skin so it would not stick together during gluing. I aligned everything prier and marked it on the husk so I would be close with the alignment. I also made temples of the top and bottom so I could lay this on top after the wing was skinned and mark the servo bays and the ailerons and flaps. I glued the top first and then the bottom. It took me until 10:00 to set the last skin. It all came out very nicely. Next I will trim and apply the LE then cut the ailerons and flaps out, keeping my fingers crossed that it goes as well as the stabilizer did.
TB</div>
ID:	1548049   Click image for larger version
ID:	1548050   Click image for larger version
ID:	1548051   Click image for larger version
ID:	1548052   Click image for larger version
ID:	1548053   Click image for larger version
ID:	1548054   Click image for larger version
