RE: Turbine cool down - pulsating vs. constant
Doesn't really matter.
I think that the pulsating cooldown is easier to achieve electronically. Anything between 1000 rpm and 5000 rpm should be fine. All it does is prevent the rear bearing from soaking up too much heat and gumming up the oil on it.
Make sure you have the pump switched off so you don't accidentally spill fuel into the cc while cooling down.
