RCU Forums - View Single Post - 2300 temp problem.
Old 08-05-2003 | 03:28 PM
SJN
Default 2300 temp problem.
When I turn on my ECU, my turbine begins to cool down imidietly....
I borrowed a terminal, and it reads 1020 C all the time.
So I tried fiddling a bit with the cables and stuff under the front cover. Strangely,If I remove the glow adapter, the temp goes to zerro.
But, if I calibrate the temp sensor with the glow adapter off, I can put it on 20 degrees C. If I heat it with a lighter, then the temps read out correctly all the way up, and down again . But as soon as I put back the glow adapter the temp goes to 1020 again
Anything I can do or check to make it work before I send it in ?
SJ.
