RE: Rabbit 20 Lb Thrust
Larry:
Software upgrade is at no charge since you have the later version ECU. Battery you have will be fine. The important thing with LiPo is a minimum 20c rating.
Kero conversion including burner, internal burner fuel system, new case (required) kero start solenoid will be $400.
Upgrade to the new starter which includes, starter, housing, housing cover will be $125.
All conversion parts will be covered under the terms of our Lifetime warranty as will your Rhino after service.
Best regards,
Eric
