This is where I initially got the idea;
header tanks;
http://www.rcuniverse.com/forum/m_10...tm.htm#1049404
press regulators
http://www.rcuniverse.com/forum/m_39...tm.htm#3980908
Is my main tank simply too big? Could I fit a couple same size tanks with this setup? What about a Cline regulator/pressurized tank or a Iron Bay regulator to help with fuel feed at all attitudes?
Maybe my setup had something to do with my troubles getting my saito tuned in. It wound up running backwards a lot
. I know minnflyer has mentioned the fuel setups are a common problem with engine run issues.
Thanks again gang
