RCU Forums - View Single Post - Turbine cool down - pulsating vs. constant
Old 01-15-2011 | 03:27 PM
basimpsn
Default RE: Turbine cool down - pulsating vs. constant
I guess it all depends on the size of the engine. Your best bet is to use a variable power supply on the starter and adjust the motor speed while checking the air flow at the tail cone. Then use that data I'm guessing your are using electro
dynamic ecu?
Xicoy.com fad06
