RE: Turbine cool down - pulsating vs. constant
I would think one could shoot for the best rpm to power draw ratio...
to get the most rpms out of the least amount of battery power
That could also change from starter motor to starter motor.
You could also use an "external booster battery" for constant starter cooling as not to drain the onboard ECU battery.
There a thread here on RCU about that as well.
