RCU Forums - View Single Post - Need Help Tuning a Carb
Old 01-15-2011 | 07:15 PM
Cowboy26a
Default RE: Need Help Tuning a Carb
I will definately check the reed assembly. I haven't tried the larger carb on the motor in the plane as it is a pain to swap engines, I was able to change the ring without taking the motor out off the plane. I will try the 18 inch prop on the test motor and see what the idle does. Thank for the reply. Pat
