RCU Forums - View Single Post - Need Help Tuning a Carb
Old 01-15-2011 | 07:17 PM
av8tor1977's Avatar
av8tor1977
Default RE: Need Help Tuning a Carb
Check me on this, but I think the WT-610 is a 13.7mm venturi, which is too large for a Ryobi.
If the engine just won't go below 3000 rpms no matter what you do, it probably has an air leak somewhere. The way you describe it running for a bit at idle and then slowing down and quitting sounds like a too rich idle.
AV8TOR
