RE: pull start is stuck
I'm no nitro expert,but did you run that first tank super lean and lock up the motor.It should be a little hard to pull when new,you said you took the glow plug out and still couldnt pull it.I would check the pull start assembly,make sure something did not break inside,then i would start checking the motor.
