RE: Intermittent Signal Lost 2.4??
Ummm.. covering it with anything isn't a cure. Moving it or the receiver away from this metal rod IS a solution. The potential problem is not that it may not be insulated, but that it is metalic and in close proximity to the receiver antenna.
If your intermittent signal loss is no longer an issue, it's probably because you did something else, not that you put rubber tubing over the metal rod.
CGr.
