Hi,
Here is MK Magic 60 drawing in PDF as promised earlier above:
http://www.algonet.se/~boem/Drawings...0_Scale1-1.pdf</p>
I scanned the orginal MK Magic 60 plan first to TIF (with LZW compression) 400 dpi in greyscale to preserve all detail and the file was as expected huge (about 250 MB) but that is no problem for a computer to handle these days. Then I horizonted the the drawing in a drawing program using the fuselage centerline to get it level and then printed to Adobe PDF (about 23 MB). Result is as above link. Good quality preserved - zoom into the PDF and You will see every thin line, all is there. Hope someone have use of it. I will scan the wing- and stabribs also from the kit balsa sheets, without them it is difficult to build the wing and stab since not much of side view of the ribs are shown on the drawing. It will take some days before that is finished.
/Bo</p>
