RE: PRIMING PROBLEM
Are the reeds sealing against the reed block? If you have a serious leak here, the pressure pulses to the carb will be weak. Also the pumping efficiency of the engine will be severely limited. The engine can still run though if it gets enough fuel and once it fires, the rapid motion of the piston can overcome the leaking reed and force it to seal. Performance would be limited though. Certainly worth a visual check of the reeds.
